Options for Uninstalling Siebel CRM
This topic is part of About Uninstalling Siebel CRM.
This topic summarizes the uninstallation options for the Siebel CRM modules described in this guide. The following uninstallation options apply for Siebel CRM modules. For details, see Uninstalling Siebel CRM.
Full uninstallation. Removes the installed Siebel CRM software module. For details, see Performing a Full Uninstallion.
Restoring a prior release. Restores an installation of a prior release that uses the new installer (Siebel CRM 21.2 or later). For details, see Restoring a Prior Installation and Configuration.
Note: You can also restore a prior installation that does not use the new installer (Siebel CRM 21.1 or earlier). The release that you can restore (or roll back to) and the specific steps you must take depend on how you had originally installed the Siebel CRM software modules. Different methods are provided for different situations. Make sure to use the correct method for your situation. For more information about this task, refer to the rollback uninstallation instructions in the Siebel Installation Guide for your operating system for your prior release, such as Siebel CRM 21.1 or earlier.
Related Topics
Requirements for Uninstalling Siebel CRM
