Mapping End Point URLs for all Oracle Real-Time Scheduler and Siebel Web Services
This integration uses the SBL_ORS_Endpoint_Definition DVM to map the end point URL for each Inbound Web Service exposed by Oracle Real-Time Scheduler and Siebel CRM.
Columns You Use to Map an Activity Status
To map a Activity status, you use the following columns:
Column 1: Service Name
Column 2: Endpoint Url
Requirements for Mapping an End Point URL
If you use the SBL_ORS_Endpoint_Definition DVM, then you must make sure your mapping meets the following requirements:
Update Endpoint URL for each of the Service Name accordingly based on physical machine name.
Examples of Mapping an End Point URL
| Service Name | End Point URL |
Employee Maintenance |
For ORS 2.1 http://<ORSserver name>:<port>/ouaf/XAIApp/xaiserver/M1-EmployeeMaintenance For ORS 2.3 https://<ORSserver name>:<port>/ouaf/webservices/M1-EmployeeMaintenance |
ShiftExceptionORSWebService |
https://<Siebelserver name>:<port>/eai_<lang>/start.swe?SWEExtSource=WebService&SWEExtCmd=Execute&WSSOAP=1 |
