Saving Your Changes and Exiting Upgrade Tuner
Use this procedure to save your changes and exit Upgrade Tuner.
To save your changes and exit Upgrade Tuner
Evaluate the changes you have made and revise them as needed.
Upgrade Tuner does not revise the upgrade files until you exit.
Click Save and then Exit.
Click Yes in the pop-up window that asks you to confirm if you want to save and exit.
Upgrade Tuner applies your changes to the upgrade files and exits.
