Starting and Stopping Siebel Upgrade Tuner
Environments: Test environment only. Does not apply to production environment.
Platforms: Windows and UNIX only.
Databases: All databases.
This topic describes how to start the Upgrade Tuner (upgtuner) from the Siebel Server installation directory on a Windows host. It also describe how to save or discard your changes when exiting Upgrade Tuner.
Use the Upgrade Tuner to improve the performance of table creation, index creation, and SQL execution during the production upgrep step in the test environment.
Requirements
In the test environment, you must have completed the production upgrep step.
You must have run the Logparse utility on the production upgrep log files. See Summarizing Siebel Log Files Using the Logparse Utility.
For UNIX platforms, you must have transferred files to a Windows host on which a Siebel Server is installed. See Transferring UNIX Files for Use by Siebel Upgrade Tuner.
