Independently Apply RepositoryUpgrade Schema Changes
If your DBA would like to manage RepositoryUpgrade schema changes, you can instruct RepositoryUpgrade to generate a Data Definition File which the DBA can then use to apply the schema changes external to Siebel CRM utilities.
$SIEBEL_HOME).To independently apply RepositoryUpgrade schema changes
Run RepositoryUpgrade.exe with the
-6input argument set toY, for example, as follows:RepositoryUpgrade.exe -s C:\$SIEBEL_HOME\ses\siebsrvr -t CQ203003 -u QADMIN -p ******** -o Q203 -d DB2390 -y QADMIN -z ******** -e Q203 -g ENU -i N -c SSEROLE -j Y -6 YThe purpose of setting the
-6input argument toYis to export the database schema without applying the changes. -
After execution, the DBA must execute
generate_schema.ddllocated in the following folder to apply the physical schema changes to the database:ses\siebsrvr\log\RepositoryUpgrade_<time_stamp>\Common -
After the DBA has successfully applied the physical schema changes, rerun RepositoryUpgrade.exe with the same parameters but with the
-6input argument set toA, for example, as follows:RepositoryUpgrade.exe -s C:\$SIEBEL_HOME\ses\siebsrvr -t CQ203003 -u QADMIN -p ******** -o Q203 -d DB2390 -y QADMIN -z ******** -e Q203 -g ENU -i N -c SSEROLE -j Y -6 A -9 MyIntegrationWS -n N -
After successfully executing RepositoryUpgrade, follow the instructions in Running RepositoryUpgrade Utility to deliver the Oracle-supplied repository changes to your customer repository.
