Checking In Development Repository Projects
Upgrades: All upgrades.
Environments: Development environment only.
Developers who are using Siebel Tools with a local database must check in their projects to the development repository.
Make sure that all project locks in your current Siebel repository have been released to prevent inadvertent loss of development work during the upgrade.
If you are using Siebel Workflow Manager, you must run the Workflow Monitor Agent and Workflow Action Agent to completion before upgrading to the current Siebel CRM release. The S_ESCL_REQ table does not have any rows if Workflow Manager has completed successfully.
