Exporting with the Migration Schema Service
You can export a Migration Schema resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to export a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Schema Service/ExportHTTP Method: POST
Content-Type: application/json
Authorization: Basic
Request parameter:
migrationid: Use the migrationid parameter to include the migration identification value in the REST API request.
Request body:
{ "body":{ "migrationid": "<Migration Id value> } }
The following are the details for the response to a successful request:
HTTP Code: 200
Response parameters:
trackingid: String that contains the tracking identification value.
Response body:
{ "trackingid": "<tracking ID value>" }
