How to Locate Siebel Migration Resource Log Files
Siebel Migration resource files are stored in the following location:
Windows: SIEBEL_FILESYSTEM/migration/<migration id>
where:
SIEBEL_FILESYSTEM: Indicates the location of the Siebel file system.
migration:Indicates the location of all the Siebel Migration files. -
inp:Indicates the input file. -
rul:Indicates the rule file. -
<migration id>:The ID generated by the Siebel Migration Application when the user executes the migration plan.-
inp: Contains a copy of the input file used for a migration execution. -
rul: Contains a copy of the rule file used for a migration execution. -
dat: Contains all the data files generated by the export or moved from the source to target for import. -
log: Contains the log file generated by the export or import. -
schema: Contains the schema file generated schema export or moved from source for import. -
other: Contains the Web artifacts or file system artifacts for export and moved from the source for import.
