Post Installation Database Update Exit Codes
The following table describes all Post Installation Database Update (PostInstallDBSetup utility) exit codes.
| Return Code | Description (Internal Only) | Console Message |
0 |
WSRanking - Successful SeedSchema - Successful WFUpgrade - Successful TaskUpgrade - Successful |
Successfully completed WSRanking Utility Execution Successfully completed SeedSchemaSetup Utility Execution Successfully completed Workflow Upgrade Utility Execution Successfully completed Task Upgrade Utility Execution Post Installation Database Setup execution Completed |
1 |
WSRanking - NA SeedSchema - Successful WFUpgrade - Successful TaskUpgrade - Successful |
WSRanking Utility Execution is Not Applicable Successfully completed SeedSchemaSetup Utility Execution Successfully completed Workflow Upgrade Utility Execution Successfully completed Task Upgrade Utility Execution Post Installation Database Setup execution Completed |
2 |
WSRanking - NA (its RR environment) SeedSchema - NA WFUpgrade - NA TaskUpgrade - NA |
Post Installation Database Setup Scripts are not applicable for RR environments Post Installation Database Setup execution Completed |
3 |
WSRanking - Failure SeedSchema - Not run WFUpgrade - Not run TaskUpgrade - Not run |
WSRanking Utility Execution failed Post Installation Database Setup execution failed |
4 |
WSRanking - Successful SeedSchema - Failure WFUpgrade - Not run TaskUpgrade - Not run |
Successfully completed WSRanking Utility Execution SeedSchemaSetup Utility Execution failed Post Installation Database Setup execution failed |
5 |
WSRanking - NA SeedSchema - Failure WFUpgrade - Not run TaskUpgrade - Not run |
WSRanking Utility Execution is Not Applicable SeedSchemaSetup Utility Execution failed Post Installation Database Setup execution failed |
6 |
Generic Validation Error / Warnings |
7 |
Pre IP17validation |
Repository upgrade and WSRanking not applicable for pre IP17 through installer. |
8 |
Rerun Validation |
'PostInstallDBSetup' database final configuration is not required on this instance as it has already been executed in a prior install. |
9 |
WSRanking - Successful SeedSchema - Successful WFUpgrade - Failure TaskUpgrade - Not run |
Successfully completed WSRanking Utility Execution Successfully completed SeedSchemaSetup Utility Execution Error while Workflow upgrade Utility Execution Post Installation Database Setup execution Completed |
10 |
WSRanking - Successful SeedSchema - Successful WFUpgrade - NA TaskUpgrade - NA |
Successfully completed WSRanking Utility Execution Successfully completed SeedSchemaSetup Utility Execution Workflow Upgrade Utility Execution is not Applicable Task Upgrade Utility Execution is not Applicable Post Installation Database Setup execution Completed |
11 |
WSRanking - NA SeedSchema - Successful WFUpgrade - Failure TaskUpgrade - Not run |
WSRanking Utility Execution is Not Applicable Successfully completed SeedSchemaSetup Utility Execution Error while Workflow upgrade Utility Execution Post Installation Database Setup execution Completed |
12 |
WSRanking - NA SeedSchema - Successful WFUpgrade - NA TaskUpgrade - NA |
WSRanking Utility Execution is Not Applicable Successfully completed SeedSchemaSetup Utility Execution Workflow Upgrade Utility Execution is not Applicable Task Upgrade Utility Execution is not Applicable Post Installation Database Setup execution Completed |
