Requirements for Starting the Siebel Upgrade Wizard After Errors
If the Siebel Upgrade Wizard stops due to errors, verify that you have met these requirements before restarting the wizard:
Carefully review the relevant log files to make sure that your upgrade has completed successfully up to that point.
If you are continuing a previous and incomplete schema upgrade, do not change the Log Output Directory that you previously selected.
If problems with your environment prevent the upgrade from restarting, you must restore the database from the prior base version (the version from which you are upgrading).
If you have to restore your database and restart the upgrade, delete or store the upgrade log files. The files are located in the following directory:
Windows:
SIEBEL_ROOT\log\PROCESS\output
UNIX:
$SIEBEL_ROOT/log/PROCESS/output
Also delete the
state.log
file. It is located in the following directory:Windows:
SIEBEL_ROOT\log\PROCESS\state
UNIX:
$SIEBEL_ROOT/log/PROCESS/state
