Requirements for Upgrading the Development Environment
Upgrades: All upgrades.
Environments: Development environment only.
Before you upgrade your development environment, make sure that the development database configuration meets the database requirements outlined in Verifying Database Configuration, and meets the requirements depicted in Siebel Installation Guide.
If your development environment platform is DB2 for Windows and UNIX, see Siebel Database Upgrade Guide.
If you have not already done so, copy the Upgrade Planning Worksheet, located in Siebel Upgrade Planning Worksheet and fill out the appropriate fields with the information you require to perform the upgrade. Contact your database administrator or systems programmer for help in completing the worksheet. Also, refer to Information Required by the Database Configuration Wizard for a description of the information you are required to enter when you run the Database Configuration Wizard to perform upgrade operations.
