Reviewing the Extracted Storage Control File
After you have extracted the storage control file, you must carefully review and edit it to meet your requirements.
Note: If you extracted the storage control file on a Siebel Server
that is on a UNIX operating system platform, and you would like to
amend the file using the Siebel Database Storage Configurator utility
(dbconf.xls), transfer the storage control file to a Microsoft Windows
computer which has Microsoft Excel installed using a BINARY FTP file
transfer mode. Using BINARY FTP transfer ensures that carriage returns
in the storage control file are maintained and transferred correctly.
This task is a step in Process of Preparing the Storage Layout of the Schema.
To review the storage control file
Navigate to the storage control file which is located in the directory that you specified when you ran the Database Configuration Wizard to extract the file.
Check the following parameters in the control file and modify them as appropriate for your database.
Note: Do not change the defaults for the following parameters in [Object 1] in the storage control file: IndexStogroup, IndexBp, PriQty, SecQty.[Object 1]
Type = Defaults Name = Defaults Database = $DbnamePrefix0000 Tablespace = SIEBTS00 Stogroup = $StogroupTables IndexStogroup = $StogroupIndexes IndexBp = $IndexBufferPool Bufferpool = $4KBufferPool Locksize = Page SegSize = 32 LockMax = 0 PriQty = 48 SecQty = 1440 PctFree = 17 FreePage = 0 Compress = Yes Define = No Erase = No CCSID = $DbType[Object 2]
Type = Database Name = $DbnamePrefix0000 LockSize = Page[Object 3]
Type = Tablespace Name = SIEBTS00 Database = $DbnamePrefix0000 Bufferpool = $4KBufferPool Stogroup = $StogroupTables LockSize = PAGE LockMax = 0 SegSize = 32 PriQty = 48 SecQty = 1440 PctFree = 17 FreePage = 0 Compress = No Partitions = 0 Define = 0 Erase = 0Once you have a storage layout that you are satisfied with, you are ready to continue with your upgrade.
Every time you modify the storage control file, you must validate it again. For additional information, see Validating the Extracted Storage Control File.
