Running the PRET Jobs for the Target Database
Perform the following procedure to run the PRET jobs to prepare the target database for table creation during the in-place upgrade.
To run the PRET jobs
On the Target Database In-Place Upgrade Menu, select option 3: Pret, and press Enter.
Run the job using the JCL in data set
DSNHLQ.SIEBEL.INSTALL.JCL(SUBPRET).This triggers the first PRET job, which then automatically submits the next PRET job in sequence. The number of PRET jobs that are automatically submitted varies according to your upgrade path.
Verify that the job ran successfully with a return code of 0. For information, see Verifying JCL Upgrade Jobs.
After submitting the job, enter
cancelon the command line or press PF3 to save changes.All jobs must complete successfully before you proceed to the next step.
On the Target Database In-Place Upgrade Menu, select option 4: PretFINS, and press Enter.
DSNHLQ.SIEBEL.INSTALL.JCL(SUBPRETF).This triggers the first PRET job, which then automatically submits the next PRET job in sequence. The number of PRET jobs that are automatically submitted varies according to your upgrade path.
Note: You only have to perform this step if you are performing an Siebel Industry Applications upgrade.Verify that the job ran successfully with a return code of 0. For information, see Verifying JCL Upgrade Jobs.
After submitting the job, enter cancel on the command line or press PF3 to save changes.
All PretFINS jobs must complete successfully before you proceed to the next step.
