Attribute-Level Conflicts and Errors
The default resolutions for the attribute conflicts can be overridden by selecting the Override option. Select the Override option with caution because you might overwrite other users’ changes that were already checked into the MAIN Workspace. If you select the Override option by mistake, then you can clear it to resolve the issue.
Errors can happen on attributes when the merge process is unable to set the correct value. Common errors are when there are inconsistencies in the repository and a foreign key is missing.
You can analyze the error further by viewing the appropriate log files.
