Help Menu
The following table describes the menu items available in the Help menu.
Menu Item (Siebel Tools) | Menu Item (Web Tools) | Description |
Contents |
Contents |
Opens Siebel Tools Online Help. |
Technical Support |
Technical Support |
Displays the Technical Support Information dialog box that includes information that Technical Support might require, such as the version number of your Siebel Tools/Web Tools installation. |
About Record |
About Record |
Opens a dialog box that displays information about the current object, including the object creator and creation date. |
About View |
About View |
Opens a dialog box that displays information about the current screen, business object, and view, including applet layout. |
N/A |
About Repository |
Opens a dialog box that displays information about the Siebel Repository, Schema Version, Language, Runtime Version, and Published Type. |
About Siebel |
About Siebel |
Opens a dialog box that displays Siebel copyright information. |
About SRF |
N/A |
Opens a dialog box that displays information about the most recent full incremental compile. |
About Visible Views |
N/A |
Displays the list of views in the repository and if each view is visible. Visibility for each view depends on the license key you use when you install Siebel Tools. For more information, see Description of the About Visible Views Dialog Box. |
Using Help |
N/A |
