Modifying a Symbolic String to Globally Update Display Values
You can configure Siebel CRM to make global modifications to the values it shows in the Siebel client. For example, this feature can be useful in the following situations:
You want to modify all instances of the word Account that Siebel CRM shows in the Siebel client to Customer.
You want to deploy Siebel CRM specific to an industry in a locale other than English. The text strings that it shows in the Siebel client might not be appropriate for this industry.
To modify a symbolic string to globally update display values
Set the language mode.
For more information, see Setting the Language Mode.
In the Object Explorer, select Symbolic String, then the Symbolic String Locale object type.
For more information, see Displaying Object Types in the Object Explorer.
In the Symbolic Strings list, select the Symbolic String record that you want to modify.
Modify the value of the String Value property.
Deliver the projects that include the objects that reference this symbolic string.
