Setting System Preferences for Parallel-Development Workspaces
The following table describes the system preferences that must be set if using parallel development for Workspaces.
System Preference Description
Enable Integration Workspaces
Administrators set this preference to Y to enable parallel development for Workspaces. The default value for this preference is N.
After a parallel development for Workspaces merge is successful, the default value for this preference will be Y.
When an administrator changes the Enable Integration Workspace value, services must be restarted for the changes (the latest Integration Workspace preferences on the server side) to take effect.
Enable Tools Workspace Deliver
Administrators set this preference to Y (default value) to deliver and publish Workspace changes. If you do not want to deliver Workspaces, then set this preference to N.
When an administrator changes the Enable Tools Workspace Deliver value, services must be restarted for the changes (the latest Integration Workspace preferences on the server side) to take effect.
Integration Workspace Prefix
Integration Workspaces start with the prefix value int, which is derived from the Integration Workspace Prefix preference.
If required, the administrator can set up a new Integration Workspace prefix value.
When an administrator changes the Integration Workspace prefix value, services must be restarted for the changes (the latest Integration Workspace preferences on the server side) to take effect.
Workspace Admin Responsibility
This responsibility is granted only to Workspace administrative users who will have the full privileges to manage the MAIN/Integration Workspace.
For more information about the detailed tasks of Workspace Administrators, see Workspaces Administration.
Workspace Prefix
Developer Workspaces start with the prefix value dev, which is derived from the Workspace Prefix preference.
If required, administrators can set up a new Workspace prefix value – see Adding the Workspace Prefix System Preference.
When an administrator changes the Workspace prefix value, services must be restarted for the changes (the latest Workspace preferences on the server side) to take effect.
