Using Shortcut Keys to Run a Query
You can use a shortcut key to run a query.
To use shortcut keys to run a query
  1. In the Object Explorer, click the object type that you want to locate.
  2. In the Object List Editor, enter ALT+Q in Web Tools.
  3. In the Object List Editor, enter the query.
    For more information, see Simple Query Operators and Compound Query Operators.
  4. Press the ENTER key.
    The query results are returned.
