Using Web Templates
A Web Template is an applet in Web Tools that displays the HTML code of a Siebel Web Template in an editor and also lets you preview the object design.
To use the Web Templates applet
  1. In the Object Explorer, select the Web Template object.
    To filter the templates, use the filter preceding the object list or run a query using the object's Menu (cogwheel icon) in the Object List Editor applet.
  2. Drill down on the Web template that you want to view or modify.
    Note: Web Tools displays the HTML code for Siebel Web Template in the Object List Editor. You open a Workspace to modify it - see Opening Existing Workspaces.
  3. If the Web template is editable, you can edit the HTML code in the editor.
    You can customize the editor with options such as auto-close tags, hints, display of line numbers or Object Design hierarchy, and indentation. The settings you select are automatically available whenever you access the editor.
  4. Click Preview (the eye-shaped icon) to preview the object design.
    You can toggle between the editor and preview.
  5. Click the Back button to exit the preview.
