Using the Right-Click Menu
Note: Right-click is available only in Siebel Tools.
A right-click menu is a type of context-sensitive menu that appears if you right-click an object or an element. It allows you to do the following:
  • Create, copy, or delete a record.
  • Undo modifications that you make to a record.
  • Display the name and status of a toolbar. You can right-click any toolbar. You can also customize how a toolbar appears.
  • Lock an object.
  • Add an object to an archive.
  • Access wizards.
