Changing Case
Siebel VB does not modify the case of characters that it formats, by default. To instruct Siebel VB to modify the case of a character, you can use the following characters:
  • < (Less than). Converts output characters to lowercase.
  • > (Greater than). Converts output characters to uppercase.
