Error Code and Error Text for Siebel VB Errors
The following table lists the run-time errors that Siebel VB returns. The On Error statement can handle these errors. The Err function can query the error code and the Error function can query the error text. For more information, see the following topics:
Error Code Error Text
5
Illegal function call
6
Overflow
7
Out of memory
9
Subscript out of range
10
Duplicate definition
11
Division by zero
13
Type Mismatch
14
Out of string space
19
No Resume
20
Resume without error
28
Out of stack space
35
Sub or Function not defined
48
Error in loading DLL
52
Bad file name or number
53
File not found
54
Bad file mode
55
File already open
58
File already exists
61
Disk full
62
Input past end of file
63
Bad record number
64
Bad file name
68
Device unavailable
70
Permission denied
71
Disk not ready
74
Can't rename with different drive
75
Path/File access error
76
Path not found
91
Object variable set to Nothing
93
Invalid pattern
94
Illegal use of NULL
102
Command failed
429
Object creation failed
438
No such property or method
439
Argument type mismatch
440
Object error
901
Input buffer is larger than 64K
902
Operating system error
903
External procedure not found
904
Global variable type mismatch
905
User-defined type mismatch
906
External procedure interface mismatch
907
Pushbutton required
908
Module has no MAIN
910
Dialog box not declared
