Adding Additional Help Topics to an iHelp Item
Complete the following procedure to add additional help topics to an iHelp item.
To add additional help topics to an iHelp item
  1. Navigate to the Administration - iHelp screen, then the All iHelp Items view.
  2. Select the iHelp item you want to work with, and then navigate to the Related iHelp view.
  3. Create a new record on the Related iHelp form, select an iHelp item from the iHelp Item dialog box, and click OK.
You can use the numbers in the Order field for each help topic to specify the order in which the help topics appear in the iHelp item.
