JavaScript Application Programming Interface
The JavaScript application programming interface (API) follows:
SiebelApp.S_App.TriggerUPTEvent(inputPropSet)
Example code for this API follows:
var uptRecord = CCFMiscUtil_CreatePropSet();
var details = CCFMiscUtil_CreatePropSet();
uptRecord.SetType("UPT");
uptRecord.SetProperty("Object Type", "Application");
uptRecord.SetProperty("Object Name", "Siebel Universal Agent");
uptRecord.SetProperty("Event Name", "UPTClientScript");
uptRecord.SetProperty("Event Sub Name", "Test");
uptRecord.SetProperty("Event Source", "Client Script");
uptRecord.SetProperty("Event Context", "Test UPT");
details.SetType("UPT Details");
details.SetProperty("Detail1", "Test UPT Value1");
details.SetProperty("Detail2", "Test UPT Value2");
uptRecord.AddChild(details);
SiebelApp.S_App.TriggerUPTEvent(uptRecord)
Information about the input property set follows:
The Object Type property is a value of Applet, Application, or BusComp. This default value is Application.
The Object Name property is a value that you specify. The default value is the application name from the configuration file.
The Event Name property is a value of UPTGeneric, UPTClientScript, or UPTServerScript. The default value is UPTClientScript.
The Event Sub Name property is a value that you specify. You can specify no value.
The Event Source property is a value that you specify. The default value is Client Script.
The Event Context property is a value that you specify.
