Running Interactive Assignment
Running Siebel Assignment Manager in interactive mode allows end users to make real-time assignments. End users can review a list of potential assignees generated by Assignment Manager, then select and confirm, or override the assignment from the generated potential candidate list. For example, a call center agent might review potential candidates for an activity, then based on the candidates' assignment scores, expertise, or workload, assign the best candidate for the job.
The Activity and Service Request assignment objects are predefined to use interactive assignment, which allows you to assign employees to activities and service requests in real time. However, you can configure other assignment objects to use interactive assignment.
For information about how to configure assignment objects to use interactive assignment, see Configuring Assignment Objects for Interactive Assignment.
You can run interactive assignment using any of the following:
Siebel Web Client (also known as zero-footprint client)
Command-line Server Manager (srvrmgr) program
Siebel Developer Web Client
Siebel Mobile Web Client users running Assignment Manager in interactive mode do not make real-time assignments, because any interactive assignments made by mobile users are not applied to the server until these users resynchronize.
The requirements for interactive assignment are that the:
Assignment Manager component is Online
Server Request Broker component is Running
