Setting Up Templates for the Auto Document Feature of Siebel Communications
Administrators must set up agreement templates for the Auto Document feature to work properly.
To set up a template for the Auto Document feature
- Navigate to the Administration - Document screen, then the Proposal Field Mappings view.
- In the Business Objects list, add a record for the mapping information.
- In the Business Object field, select Service Agreement.
- In the link bar, click Proposal Templates.
- In the Templates list, add a record, and complete the necessary fields. - Some fields are described in the following table. - Field - Comments - Default - Select this check box if you want to designate this template as the default template. Note: The Auto Document feature works only if you designate an agreement template as the default template.- Category - Select Agreement. - Mapping Name - Select the name that you created. - Template File Name - Select the template file to use.
