Incoming Concurrent EAI Requests and Session Management
When an external application sends a SOAP request to the Siebel EAI Object Manager and it uses a Session Token, the Siebel application uses the information in that token to find the EAI Server Task that created that Session Token if the Application Interface Profile parameter, No Session Preference in EAI-SOAP is set to FALSE.
A Session Token will route the incoming request to a specific EAI Server Task. If that Server Task is unavailable for any reason the Siebel Server returns an error response.
"Token might have been expired or logged out by the user. (SBL-UIF-00880)."
If an external server spawns multiple, simultaneous requests that use the same Siebel Session Token and they all reach the Siebel Server at the same time, one will be processed, and the others will receive the previous error because the EAI Server Task is unavailable as it is processing a request.
You cannot expect to have all the requests using the same Session Token to process simultaneously. One will process, the others will fail.
