Mapping External Columns to Siebel CRM System Fields
This task is a step in Process of Configuring External Business Components.
When the EBC is defined, you must map the Siebel CRM system fields to the corresponding external table column. System field mapping is accomplished at the column level, rather than using business component user properties. Specify the System Field Mapping column attribute if you want to map a Siebel system field to a column.
By default, the Siebel CRM system fields are not included in the generated SQL for external tables.
System Field Mapping is used to specify the mapping between table columns and Siebel CRM system fields. The following is a list of the system fields that can be mapped to external table columns:
Conflict Id. (Optional).
Created. (Optional) Datetime corresponding to when the record was created.
Created By. (Optional) String containing the user name of the person and the system that created the records.
Extension Parent Id. (Optional).
Mod Id. (Optional).
Non-system. (Optional).
Updated. (Optional) Datetime corresponding to when the record was last updated.
Updated By. (Optional) String containing the user name of the person and system that last updated the record.
Id. Mandatory. The single column unique identifier of the record. A column in the external table must be mapped to the Id field.
