Determining Required Maps
The Integration Object Browser lists the existing integration object maps. Use this browser to determine which maps you need to create.
To determine which maps to create
  1. Navigate to Administration - Integration, then Data Maps.
  2. In the Data Maps list, query for the integration objects you want to map.
