Advantages and Disadvantages of Using RBR Logging
Advantages of RBR logging include the following:
Since EIM inserts all the information (data as well as column info) into the S_DOCK_TXN_LOG table, in cases for which mobile clients bring about synchronization problems, RBR logging is beneficial in making troubleshooting easier.
The row-by-row mode is required for logging update transactions. If the SET BASED LOGGING parameter is not set, then EIM runs in RBR for update operations when transaction logging is enabled. RBR is also required for merge processes when transaction logging is enabled.
Note: When running merge processes with transaction logging, SET BASED LOGGING = FALSE is required. If EIM performs a merge with set-based logging instead of RBR, transactions are not written to S_DOCK_TXN_LOG even though TRANSACTION LOGGING is set to TRUE. The merge works correctly, but remote clients cannot get the transactions and are out of synch as a result.
A disadvantage of RBR logging is that RBR logging affects performance, especially with large imports and deletes.
