Running an Export Process
You may run an export process once you have:
  • Identified the data for export processing
  • Prepared the related EIM tables
  • Modified the EIM configuration file accordingly
Run the export process by completing the procedures in Running EIM.
If you are exporting data that pertains to organizations and divisions, it may be necessary to run additional SQL statements against the EIM table to complete the export of names from the S_BU base table (used for organizations).
To populate the BU columns from the S_BU base table
  1. In the Admin directory within the Siebel Server root directory, open the file named eim_export_lookup_bu_name.sql.
  2. Locate the appropriate SQL statement for the base table that you are exporting.
  3. Modify this SQL statement if necessary and run it against the EIM table to populate the BU columns from the S_BU base table.
