CUT Receive Work Order Data Workflow
This workflow receives work order data that is modified in a back-office application because the data must be updated in Siebel Energy.
Workflow Description
This workflow performs the following actions:
  1. Receive Work Order Update. This step uses the Receive method of the EAI MQSeries Server Transport business service.
  2. Convert to Internal. This step uses the XML Document to Integration Hierarchy method of the EAI XML Converter business service.
  3. Update Work Order. This step uses the Insert or Update method of the EAI Siebel Adapter business service.
