Scenario for Using Fraud Management in Siebel Energy
This topic gives one example of how fraud management might be used. You might use fraud management differently, depending on your business model.
A CSR is responsible for handling fraud issues for your residential customers. A customer has a contract for residential electric and gas services.
Your fraud management application finds that the meter readings at the customer’s location show typical gas usage but no electricity usage. Such a pattern can mean a problem with the electric meter, a theft of energy, or a gas leak in an unoccupied residence. The fraud management application generates a fraud alert for the customer's account, with the fraud level set to Suspected, fraud type set to Theft, and fraud event set to No Electric Usage. The fraud message is forwarded to Siebel Energy. Through integration with the third-party application, the fraud data is sent to the CSR’s Siebel application, and the account is flagged as fraudulent. The Siebel application creates a fraud alert and fraud alert details and updates the customer account with the fraud level.
Siebel Energy has been configured to generate an activity to contact the customer. The fraud alert appears in the customer service supervisor's queue by default, and the supervisor assigns the fraud alert to the CSR, who examines the fraud alert. The CSR also checks for any other fraud alerts raised against the account in the last 12 months to see whether it has a history of fraud. This credit alert is the first fraud alert against the account.
The CSR looks up contact information for the customer's account inSiebel Energy and telephones the customer, intending to ask if the premises are occupied. The person who answers the phone is hesitant and claims that the premises are infrequently occupied. The CSR suspects that this situation is a case of electricity theft. The CSR updates the fraud alert's status and attaches appropriate comments.
Siebel Energy transmits this information to the fraud management application. The CSR's fraud management department then starts its formal investigation and dispatches a field service agent to the premises location.
The following image shows a possible sequence for managing fraud, which includes the following steps:
  1. Examine fraud alert.
  2. Display fraud alert details.
  3. Attempt to contact customer.
    1. If successful in contacting the customer:
      • Discuss suspected fraud.
      • Change thresholds or disconnect customer.
    2. If unable to contact customer, then disconnect customer.
  4. Update fraud alert.
Example of Sequence for Fraud Management. This image is described in surrounding text.
