Creating and Using Session Templates
Sessions can also be generated automatically using Session Templates. This feature reduces the amount of data entry required when setting up multiple events with similar session schedules.
To create a session template
Navigate to the Site Map > Marketing Templates > Session Templates view.
In the Session Templates list, create a new record, and complete the necessary fields.
In the lower list, create a new record, and complete the necessary fields.
Repeat this step for each session template created.
To use a session template
Navigate to the Site Map > Events > Event view.
In the Events list, select and drill down on the event.
In the Details form, from the Session Template field, click the select button.
In the Sessions dialog box, select the session, and click OK.
You can add a group of sessions to an event using a session template. As application administrator, you must set up a session template before you can associate it with an event, see Defining an Event.
To associate a session template with an event
In the Event list, select and drill down on the event.
Click the Schedule view tab, and then click Sessions.
In the Sessions list, create a new record.
In the Sessions list, click the select button in the Session Template field to select a session template.
To see the session associated with the event
