Adding MRDs and Linking Features
Product marketing managers can group similar features together into an MRD and track the development of the MRD in Release Manager. Authors of the MRDs can attach electronic copies to MRD records.
To add an MRD and link features
Navigate to the Release screen, then the Marketing Requirement Documents view.
Add a new MRD record, and complete the fields as appropriate.
Some fields are described in the following table.
Field Comments Associated Parties
Select the individuals associated with the MRD. Set the author as Primary.
Release
Select the name or number of the product release associated with the MRD.
If you want to associate features with the MRD, then complete the following steps:
Drill down on the MRD number (#) field, and click the Features view tab.
Create new feature records, and complete the fields as appropriate.
