Evaluate Condition Method
Evaluate Condition determines whether a condition is met.
Arguments
The following table describes the arguments for this method.
| Argument Name | Description |
Current Amount |
The value used to evaluate whether the condition is met. |
Operator |
The operator used for the calculation. Values
include |
Target Amount |
The value to compare with the current amount.
You can specify minimum and maximum bounds separated by a colon ( |
Return Value
The following table describes the return value for this method.
| Return Value | Description |
Compliance Flag |
A value that indicates whether the condition is met. |
