Setting Component Job Parameters for the Preventive Maintenance Engine
Complete the procedure in this topic to set the component jobs parameters for the preventive maintenance engine. For more information about server components and component parameters, see Siebel System Administration Guide.
This task is a step in Process of Administering Preventive Maintenance.
To set component job parameters for the Preventive Maintenance Engine
  1. Navigate to the Administration - Server Management screen, Jobs, then the Job Detail view.
  2. Create or edit a component job for the Field Service Preventive Maintenance Engine (alias FSPrevMnt) server component.
  3. Add or modify the server component parameters, as needed.
    For more information about the applicable parameters, see Parameters for the Preventive Maintenance Engine.
