Setting Up Lists of Values
You can set up Lists of Values (LOVs), including LOVs for Siebel Quality, for use in Siebel Business Applications. For more information about setting up LOVs, see Siebel Applications Administration Guide.
The following table lists the LOVs to set up before using Siebel Quality.
| Field | Type Value for LOV Items | Description | Example LOV Items |
Area |
PROD_DEFECT_AREA |
The functional product area. |
Accounts Orders |
Browser |
PSTASK_CLIENT_BROWSER |
The type of Web browser running in the test environment. |
IE 5.5 NS 6.2 |
Client OS |
PSTASK_CLIENT_OS |
The type of operating system running on the client. |
Win 2000 Mac OS |
Database |
PSTASK_CLIENT_DB |
The type of database running in the test environment. |
IBM DB2 MS SQL Svr 7.0 |
Priority |
PROD_DEFECT_PRIORITY |
The relative importance of the issue. |
P1. Critical P3. Medium |
Server OS |
PSTASK_SERVER_OS |
The type of operating system running on the server. |
HP-UX 11i Solaris 8 |
Severity |
PROD_DEFECT_SEVERITY |
The severity of the issue. |
3. Wrong Behavior 4. Minor Error |
Special Tag |
PD_SPEC_TAG |
The statuses or actions that other fields do not identify. Use for reporting, querying, exporting, or localization purposes. |
BETA3 HIGH RISK |
Status |
PROD_DEFECT_SUB_STATUS |
The implementation or development stage. |
Open-Disagree Closed-Verified |
Subarea |
PROD_DEFECT_SUB_AREA |
The functional product area subdivision. |
Expenses Fulfillment |
Substatus |
The implementation or development substage. |
Unassigned Approved |
Type |
PROD_DEFECT_TYPE |
The type or classification for the change request. |
Product Defect Enhancement |
Siebel Application Interface |
PSTASK_SERVER_OS |
The type of operating system running on the Siebel Application Interface. |
AIX 4.3.3 Win NT 4.0 |
This task is a step in Process of Administering Siebel Quality.
