Aspect BC ReadOnly: History
Use this user property to set the business component to read-only mode, if the value of the field specified in the user property is Y.
| Property | Description/Value |
Value |
Calc Locked Flag |
Parent Object Type |
TNT History Opportunity business component |
Usage |
When Aspect is defined and the current aspect is Aspect, then the current record becomes read-only when the value of the specified field is Y. |
