Associating Setup Styles and Packages with Properties
You can associate predefined setup styles and packages with properties. For more information about creating property-specific menus and packages, see Setting Up Property-Specific Menus and Packages .
This task is a step in Process of Setting Up Function Spaces.
To associate a setup style and a package with a property
  1. Navigate to the Property Administration screen, then the Properties view.
  2. In the Properties list, query for the required property.
  3. Click the link in the Property Name field, and then click the Property Style view tab.
  4. In the Property Style list, create a new record, and complete the fields as required.
    Some fields are described in the following table.
    Field Comments
    Setup Style
    Select a predefined setup style.
    Display Name
    Enter a name to be displayed for this setup style in the Siebel Hospitality user interface.
    Package
    Associate a property-specific or common product with the setup style. The product, which might be simple or customizable, must have a Product Type value of Setup Style.
