Associating Specific Spaces with a Function Space Category
You can associate a specific space with one function space category.
This task is a step in Process of Setting Up Function Spaces.
To associate a specific space with a function space category
  1. Navigate to the Property Administration screen, then the Properties view.
  2. In the Properties list, query for the required property.
  3. Click the link in the Property Name field, and then click the Category view tab.
  4. In the Category list, select the category.
  5. Scroll down to the Specific Space view tab and create a new record.
    Note: If the Back Up Required field of the category has been selected, then only those specific spaces whose Back Up Required fields are selected will be displayed.
  6. Select the specific space record and click OK.
