CanInvokeMethod: ConfirmVoidEventCheck
Use this user property to enable the Void Event Check button for only event checks with a specified Status field.
Property Description/Value
Value
[Status] = LookupValue('PS_SUBCONTRACTOR_STATUS', 'Posted')
Parent Object Type
SHM Invoice Form Applet and SHM Invoice List Applet applets
Usage
Enables the Void Event Check button for only event checks with a Status field of Posted.
