CanInvokeMethod: PostCheck
Use this user property to disable the Post Check button for only event checks with the specified Status fields.
Property | Description/Value |
Value |
[Status] <> LookupValue('PS_SUBCONTRACTOR_STATUS', 'Voided') AND [Status] <> LookupValue('PS_SUBCONTRACTOR_STATUS', 'Posted') |
Parent Object Type |
SHM Invoice Form Applet and SHM Invoice List Applet applets |
Usage |
Disables the Post Check button for only event checks with a Status field of Posted or Voided. Such event checks are read only. |
