CanInvokeMethod: ReleaseInventory
Use this user property to enable or disable the ReleaseInventory method.
| CanInvoke Method: ReleaseInventory | Description |
Value |
[TNT Disable Release Flag] AND [Id] IS NOT NULL |
Parent Object Type |
TNT SHM Functions List Applet, TNT SHM Order Function List Applet applet |
Usage |
This user property is used to enable or disable the ReleaseInventory method. If the function record has an inventory status other than Unreserved, then only the ReleaseInventory method can be invoked. |
