Default Aspect
Use this user property to define the Default Aspect property for an applet.
| Property | Description/Value |
Value |
History |
Parent Object Type |
TNT Opportunity History Assoc List Applet applet |
Usage |
When the aspect is defined, the business component user properties function that is based on the aspect is defined. The Default Aspect is defined as History. |
