Format Specifier Major
This user property is used to specify the date format on the major axis for each time scale. You use this user property to define the date formats for different time scales on the major axis of the Function Space Diary. The value is a set of name-value pairs. The first part of the delimiter represents the time scale and the second part represents the format that applies to the time scale.
| Property | Description/Value |
Parent Object Type |
TNT SHM Gantt AX Date Time Interval PopUp VBC Value: 1;MMMM YYYY;2;DDDD DD;4;DDDD DD;8;DDDD DD;16;DDDD DD;32;MMMM YYYYY;64;DDD;128;DDD DD;256;DDD DD |
TNT SHM Inventory Gantt AX Date Time Interval For Order PopUp VBC Value: 1;MMMM YYYY;2;MMMM DD YYYY;4;DDDD MMMM DD YYYY;8;DDDD MMMM DD YYYY;16;DDDD MMMM DD YYYY;32;MMMM YYYYY |
TNT SHM Inventory Gantt AX Date Time Interval PopUp VBC Value: 1;MMMM YYYY;2;MMMM DD YYYY;4;DDDD MMMM DD YYYY;8;DDDD MMMM DD YYYY;16;DDDD MMMM DD YYYY;32;MMMM YYYYY |
Usage |
Multiple time scales are available for user selection. Each time scale is referenced by a code as follows.
