Item Color Fields
This user property is used to specify the field name that is present in the Y-axis business component in the Diary.
Item Color Fields |
Description |
Value |
Compound Inventory Status |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet |
Usage |
This user property specifies the field name that is present in the Y-axis business component in the Diary. The booking color is displayed in the Diary according to the value of this user property. |
