Line Items BO Name: TNT SHM Order Entry
Use this user property to define the business object name to make technical decisions in C++ code.
Property Description/Value
Value
TNT SHM Order Entry
Parent Object Type
TNT SHM Order Item business component
Usage
Defines the business object name to make technical decisions in C++ code. This user property is active only if the business component is associated with the defined business object.
