Named Method 8
Use this user property to call an internal service method to set the split flag value for the parent menu when the TNT Split Qty Flag field is updated for a child menu item.
Property | Description/Value |
Value |
"SetParentSplitFlag", "INVOKEALL", "TNT SHM Invoice Order Item", "SetSplitValue" |
Parent Object Type |
TNT SHM Invoice Order Item business component |
Usage |
Calls an internal service method to set the appropriate value to the Split Menu Flag field for the parent menu when the TNT Split Qty Flag field is updated for a child menu item. This user property works with the On Field Update Invoke user property. |
