Prefix For Custom Product
Use this user property to define the prefix for the custom-created menus and packages in function line items.
| Property | Description/Value |
Value |
Product Prefix |
Parent Object Type |
TNT Custom Menu/Package VBC business component |
Usage |
A menu or package does not have to be predefined in the product list. A menu or package can also be created at run time. The products listed in the table in this topic are provided with Siebel Hospitality as seed data. If a user renames items in the seed data, for example, WRITE-IN Menus Per Person instead of Write-in Menu Per Person, then the value of the Product Prefix calculated field must be modified accordingly. Note: Optionally, you can define a Display Name for each product with any value. The Product
Name and Product Type must be the same for all the seed products as defined in the
following table.
| Product Name | Product Type |
Write-in Menu Per Person |
Menu Per Person |
Write-in Menu Item |
Menu Item |
Write-in Package Per Person |
Write-in Package Each |
Package Each |
Write-in Package Item Price |
Write-in Event Order Item |
Event Order Item |
